I just noticed this at the Chinese on-line retailer, ThanksBuyer.com
They are pricing the bundled versions attractively. Obviously made to compete against the APM micro 3.1
If anyone makes the leap, perhaps you could keep us informed on your experiences.
Happy flying all!!
Control your radio calibration.
Anyway...
Problem;
my "APM Pro mini Pix " won't recognise my compass. Does anyone else have a photo they can share with the proper way to connect the Compass? I'm thinking I may have had it one pin to far to the middle instead of right on the edge and maybe burnt out the compass. Any help would be great! Maybe I've already done damage by having it in the middle pins I think it's meant to be yellow far right middle above GPS with the green next to it horizontally. I had it one pin in to the left. Either way it's not being recognised. Error 99 on calibration with no movement of the live calibration.
Be aware that its power module output only 5v not 5.2 and sometime I had power warnings in my dataflash logs...
Too low power vcc it could brown out
I will be using 2 axis brushless gimal on my quad and will be powering with 5v bec since i will be using 4s battery on my quad.
On last post you said i just need to use either power moudule or esc with bec does it mean that i dont need to use power module and can power up my apm only using esc cheers
1 i would like to know if this controller supports gimbal and where to connect the wiring,
2 is it safe to use both power module and esc with bec togeather?
Anyhelp would be appriciated thankyou
I like this board connectors, easy to find and looks more safe than the Pixhawk ones but this one is 8 bits.
Scott Meese looks like you already figured it out but here is a nice diagram on the wiring, shows the compass and the compus IC socket. Below that is the pin outs
7
8
9
10
11
of 14 Next
