Starting a new thread to show what I'm working on. I'm building a new Octocopter of my own design. The goal is to use it for Aerial Photography, lifting a mid-weight camera such as a Sony Nex5. It will of course be using Arducopter for control. ;)
I started off researching the various kits on the market, and starting getting analysis paralysis. I looked at all the options such as Droidworx AD8, Cinestar, CarbonCore, and SteadiDrone. But I just wasn't happy with the design on them, particularly for the price they ask. Combined with the fact that I can be pretty frugal, and have a strong DIY ethic, I decided to just design my own.
The basis of the design relies on many of the Hobby King quadcopter parts. I liked the design of the motor mounts, they are very professional looking, even compared to some of the high end machines. And I liked that the boom mounts are blocks of aluminum instead of plastic. Very rigid. I also liked the look of the dome on their H.A.L. quad, but since they don't sell it seperately, I bought the whole kit, it's only $34, amazing! I might end up using the rest of it someday, who knows? So, I basically emptied out their stock of Talon parts, so if you need to fix your Talon quad and the parts are backordered... sorry!
Once that was settled, I set about designing the center frame. My design required a few things, namely I want all the wiring hidden. I don't want any spaghetti showing. Particularly with the ESC's, while still allowing cooling airflow. This required the center hub to be larger than is typical. I then needed a smaller subframe to house the avionics.
You can see these plates below. The larger one houses the HAL dome. You will notice the 3 blue anti-vibration grommets in the middle. This is the APM1 pattern. I did that just because. Maybe I'll use an APM1 as a stand along gimbal controller. The second plate had grommet mounting for an APM2. The final plate is the top plate, and has bolt patterns for the Ublox GPS and the magnetometer.
This next photos shows the avionics frame built up with an APM2 mounted. 25mm aluminum standoffs are used. I don't like the plastic standoffs typically used. They get loose, and lead to vibration. They also break easily. This structure ends up being quite rigid.
Here is the avionics frame mounted on top of the main frame. Yes, the main frame is HUGE. I actually don't see the point in having a tiny center frame, and then long arms. This seems like it just leads to flex, and doesn't leave you with any real estate to mount your avionics.
This photo shows one of my design features. I put some cutouts on the bottom frame for weight savings, and then made matching cutouts on the top frames. This creates some nice conduits to run wires neatly.
Here it is with the HAL dome mounted and one of the Talon arm mounts bolted in. I'm really happy with how stiff the assembly is already.
Here it is with one of the arms mounted. These are the short 220mm arms, I also got some of the 320mm arms. One may wonder how I'm going to get away with such short arms and 13" props.... Astute readers will know what I'm planning already. ;)
This last photo shows one of the ESC's in position. This is a Hobby King F-40A, it's somewhat larger than typical 20A units which is partially why the frame is so big.
That's it for now. I had the plates cut out of aluminum to start with because it's cost effective. If it all works out, I'll probably have it redone in carbon fiber plate for the weight savings. I was a little uncertain about the weight, but it looks like the frame will come in at 1070g all in aluminum. That's about 300g heavier than a Droidworx AD8, but not too bad. It will drop about 1-200g if redone in CF.
Rob I read all your posts on regroups about the open source gimble. Not sure if there is a kit yet available. Will you be sourcing the parts yourself? If you do source the parts you can count me in for two kits. You can ship them with the octo kit. I was able to change the ESC back to the one you are using and they just shipped my order so I should have it inside of 2 weeks. Once you have prices, how can I send you money? Paypal?
Hi Pablo,
Great looking gimble. Do you offer the plans or plates so I can assemble it myself? Not sure how the mounting would be with Rob's octo but I think that will get figured out. :)
Rob, I just realized about X and + config. I didn't even consider if yours was + or x config. I'm use to flying in x mode. Is it possible to mount the APM2 on your frame so it's oriented for x?
and where can I get 12x4.7 slow fly pusher and puller props??? Even at the APC store I'm not finding both of them. Only the CCW one. Maybe I will just go with the CF ones.
http://www.foxtechfpv.com/1260-carbon-fiber-propeller-cwccw-p-522.html
Here you have a lot of pictures of my camera gimbal:
Add-on for full pan:
Plate for light cameras:
Gimbal itself:
You can adjust GC with the fixed support or with the full pan add-on:
Detail of camera tray:
The dampered plate have an offset because I made a mistake in the design.
It was designed with + frame in mind, but now I use it as X frame, and I forgot to draw the holes for it.
Thanks.
Hello Robert, this is a great looking build. I have been looking for a dome for my quad and was wondering about the Hal dome. Can you tell me the diameter and height please.
Do you have a video of your new machine in the air?
Thx
Just noticed something. If i'm reading this right, it has a 6mm shaft.
http://www.hobbyking.com/hobbyking/store/%5F%5F14501%5F%5FNTM%5FPro...
And my props have a 5mm bore! Would I need to ream out the prop? Not really wanting to do that. I know I could get other props but I really like these. Very quiet and strong and seems to stabilize better also.
http://quadcopters.co.uk/10x45-pair-of-carbon-reinforced-propellers...
I thought it might be helpful for anyone else building this to have all the hobbyking links in one place so here they are:
9171000032 - Turnigy Talon V2 Carbon Fiber Extended B..
4 for $39.52
9171000027 - Turnigy Talon V2 Alloy Motor Mount Block
8 for $23.20
9171000028 - Turnigy Talon V2 M3 Hex Tapped Spacer (2..
8 for $13.44
9171000088 - Turnigy H.A.L. Motor Mount Set(1set)
8 for $29.92
9171000086 - Turnigy H.A.L. Quadcopter Dome
$5.71 though I think I will use my green hamster ball ;-)
NTM3536A-910 - NTM Prop Drive Series 35-36A 910Kv / 350..
8 for $146.32
F-40A - Hobby King 40A ESC 4A UBEC
8 for $127.92
NTM35-ACC - NTM Prop Drive 35 Series Accessory Pack
8 for $15.12
$401.15 plus shipping which isn't bad for an octo. Of course add in the parts from Rob.
Rob you think I can get the center pieces from you in a couple of weeks? I prefer CF but Aluminum will do.
Anyone using thesegrub screw type of prop adapters? I normally get the other clamp down type that comes with the 3DR motors but never liked clamping down too tightly because i didn't want to risk stressing the prop hub that could fail later in flight. With the grub screws I don't have that problem but is there some reason not to go with that type?
Pablo, what camera gimble is that? That will be my first add on :)
Rob, maybe you can help me decide on an ESC. I'm going with the NTM Prop Drive Series 35-36A 910Kv / 350W motors. I saw these that are already flashed with SimonK which saves me the trouble of uploading it. They are $18 each w/free shipping. On HK they have a lot of 30A options. You went with the hobbyking? They have a 40-50 amp ESC for $11 plus shipping. It's possible to flash it with SimonK?
This is my own design octo, It flies very stable with 2.7.3 version (stabilize mode and 0.090 P).
I use 6S Lipos (nano-tech) with Turnigy L5055A Motors (400kv), It have a width of 100cm shaft to shaft.
The frame is 3mm CF and the draw current is:
Without camera (Canon 7D + 15-85) : 40A at hover
With camera: 50A at hover.
Thanks.
Rob, do I need to get any screws? I know you said you would be sending some with the kit but wasn't sure if I would still need these.
4 of http://www.hobbyking.com/hobbyking/store/__23019__Turnigy_Talon_V2_...
8 of http://www.hobbyking.com/hobbyking/store/__23012__Turnigy_Talon_V2_...
8 of http://www.hobbyking.com/hobbyking/store/__23014__Turnigy_Talon_V2_...
about $125
Do I need these?
http://www.hobbyking.com/hobbyking/store/__23016__Turnigy_Talon_V2_...
http://www.hobbyking.com/hobbyking/store/__23015__Turnigy_Talon_V2_...
9
10
11
12
13
of 13 Next
