New to this forum. Qu4d Question.
I am wanting to know if by moving my front arms forward and the back arms closer would I bennifet from making it into a X shape at all... I have a 2014 Qu4d from steadidrone. I have all DJI gear in because I have had so many friends have there qu4ds crash...So I have a ton of spares..........
Also does anyone know where the best place to get a 4s 5200Mah battery from ...
  • Thank you John for your reply. I am wanting to do it for a more stable flight. I find that in the amost V shaped front its very agile and responsive... I am not complaing about that, for fun its amazing. For stable flights and professional videos and pictures its not. I am wanting a X shaped.. I have considered the Maveric or the X steadidrone. But the cost is silly. I am getting better quality videos with my DJI phantom 2 than I am with the Steadidrone Qu4d 2014. I am going to loose the front gimbal and put retracts on and install a H3-3D gimbal on the bottom. I am also changing the ESC from 25 amps (I know its a block) to a 30amp. I need to this to be suitable for stable flight and long flight times.. I use a 5200 mah battery.. but I am considering a 5500 or even 6000 4s. I am also considering changing motors.. but I will try the 12 inch props first for stability... obviously various types from wood to carbon fibre. Thank you again.. for the advice.. and link!!!! your a star mate.
  • Not sure of the benefits but that might put the props in the view of the camera. I had to do that for 12" props but didn't get any better flight time so went back to the 10" props which is the size that SteadiDrone recommended.
    Here's the battery I am using and getting about 10-12 minutes.
    http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=...
