I just received the new iris+ and am currently able to fly it with the RC controller but when I hold down the "DN" button on the controller I do not see any flight data, i.e. altitude, speed, battery, etc. when the iris+ is flying. I have gone through the initial setup on mission planner and am able to successfully calibrate the RC controller through the wizard tool.
Does anyone know how I can resolve this issue?
Hi, I have the same problem and beta installation did not fixed it. I still have no altitude, speed, distance, satellite and battery readings
DomagoJ H:
I was wondering if you could elaborate the steps you took to install the 3.2 beta firmware onto the iris+?
I'm still very new with this hardware setup and am still getting used to Mission Planner etc.
Udate: installation worked! jst have to be patient with firmware setup and do everything by the book.
Don't forget to run through all the calibrations after you upgrade. Also there is an Iris+ settings file you can load under config/tuning that will setup the battery levels correctly along with some other stuff.
Add on to original post:
I am able to access the Flight Data screen on the RC controller but the values stay at "0" during flight even though the flight timer starts.
