Hi folks,
APM2.0
I tried updating the firmware (3.0) and it failed. It seemed to leave the old 2.9 on though as I could still fly and connect.
I cleared the eprom through terminal and tried again. Failed again.
It downloads the firmware and then seems to freeze.
I can upload my own sketches to the APM so it seems fine.
See screen shot of when it fails.
I've tried from two PCs (both ok in the past)
Multiple USB cables
without the GPS and flashcard in
no XB connected.
Any tips appreciated.
Crispin
@ JB: thanks! That's the most annoying thing out. Will try and see.
Not my issue though as I've had the sluggish serial or a few months. Failure to upload FW is recent.
Thanks all.
Obviously you've got the com port and speed set correctly on the top right of the mission planner's firmware screen? Speed should be 115200 of course.
Quick update -
I can upload firmware (3.0.0) by compiling the code and uploading that. Worked without hassle. I can then connect with MP, view params, see HUD etc so all is peachy.
I then try upload 2.9b or 3.0 through MP and nothing. Same as before.
Something is fishy with the MP way of uploading?
