No Output in Out 2 ( counting begins from 0)
after getting the entire thing setup. it turns out i dont get any output on out 2. so i went back and did the dancing servos test and it remained true, i looked at the soldering to make sure there were no unintended bridges, looked clean. what could it be, as a temporary solution i was wondering if there is a way to code for the apm to treat in4 and out 4 as in2 and out2 so i can solve the problem and get airborne. any help with that/? as far as the out 2 issue how can i test whats exactly going on, i seem to be getting power but no signal for the servo / throttle to respond to commands. In the CLI it clearly shows through the tests that in and out on 2 are fine , so it must be a physical problem either the powers not comming through as it should or there is no servo signal coming through? ways to test this and troubleshoot would be really appreciated.
  • Hi Mahmood, this does sound like a hardware issue and it looks like you already checked your board from top to bottom. Still, can you provide clear pictures of the whole board, front and back?
  • So what i have done is i used a bunch of jumper wires to test exactly where problem is with regards to the pins that come out of out2, the power works fine , its the pin that send the servo its signal, so i just did a continuity test to make sure there weren't any cut traces till the Ic3 and its fine, so im still wondering what next to test ?3692157669?profile=original
  • I am sure this must be a hardware issue. ill post a video of the malfunction... there must be a software way around it though unless out 2 is specifically always going to be the motor in which case i cant run the autopilot correctly
