no servo response
HiI originally had some problems with uploading my code, however i managed to work it out and it was all working fine. I did a few test flights to tune the gains and after i was ready to try RTL a few days later. So i connected up everything and loaded checked it all was working via serial monitor and i got a GPS lock and all. I turned it all off and headed to the field to fly for real only to find that once there i could not get a GPS lock after 20min. I wanted to fly so i disconnected the gps so i can use FBW however i realised that the servos were not responding through ardupilot any more. I could still switch between en autopilot off, waypoint or RTL on my radio.I really wanted to fly since i was there so took out autopilot and had a normal flight with everything working. So there is no problems with my radio or servos and cables, there seems to be a problem with my board.I tested again at home and servos are not responding through the board and i cannot get a GPS lock any more. I also noticed that the reset button on the blue shield is not functioning either (i did test the solder connections and button and they are fine). The reset on the red board is working. I tried uploading the new code but i am having the same problems i had before with the code failing to upload? Any suggestions would be appreciated?
