No throttle control on arducopter
Hi
I am a complete noob at this, I have built a octo using APM 2.5, my problem is the throttle seems stuck, it starts up at a high speed but when you try to increase it just stays at the same speed.
I think I am having the same problem in this thread, tried everything and still cannot get it to work, Any help please.
http://diydrones.com/forum/topics/problem-no-throttle-control-on-arducopter-2-9-1-quadcopter-3dr?groupUrl=arducopterusergroup&xg_source=activity&groupId=705844%3AGroup%3A394475&id=705844%3ATopic%3A1118715&page=1#comments
  • Well it's 2 AM in ABQ and I swear my APM is possessed. EVERYTHING is working again. Arm/disarm and all.
    I DID NOT change ......oops...yes I did.
    I put a new GPS on the APM. I reloaded firmware 3.0.1 and the thing that got everything working was..............
    Going to the setup or test mode, I forgot which, and did an ERASE. After erase I reloaded FW. All this fu..king around for 3 days and it appears to have been something in the flash memory. From now on when I reload FW I will do the erase first !
    Anyway....things are working and I am going to fly tomorrow after a GOOD nights sleep.
    Earl
  • Problems here also...
    Here are my throttle ranges etc.
    Throttle range on input Ch3 990 - 2015 armed or unarmed.
    Outputs with throttle disarmed:
    All Ch 1-4 at 987
    Outputs with throttle all the way down armed condition:
    Ch1 1199
    Ch2 1171
    Ch3 1119
    Ch4 1227
    Outputs with throttle at mid position armed condition:
    Ch1 1435
    Ch2 1321
    Ch3 1372
    Ch4 1513
    Outputs with throttle all the way up armed condition:
    Ch1 2010
    Ch2 1901
    Ch3 1605
    Ch4 1750
    Quad level as I can see and on Mission Planner HUD looks level.
    Still can't Arm/Disarm with RC, must use MP
    Earl
  • I can't even ARM or DISARM with the RC throttle. I have to use the Mission Planner to ARM/DISARM. Once armed, I have full control from 5% to 100% throttle.
    I have been working with Mark at 3SR to solve the problem.
    No luck yet.
    My setup:
    APM 2.5
    Firmware 3.0.1
    DJI Phantom shell
    Power distribution board from 3DR
    900mhz 3DR radios
    8000 mah battery
    Turnigy 2822/17T motors
    FS-TH9X RC
    Rmilec 1.5 watt tx and companion rx
    I hope to get it fixed.
    Earl
  • My low throttle is 1100
    at 1103 the motors start and will ramp up in speed as it sits there.
    Running with no props is different from actual use.
    I have linear increase in motor speed up to the max of 1900 on throttle. All settings are the default 100%.
    Have you tried changing the THR_MIN parameter as I found with some motors, especially at 1200kv, that it was too high and lowered it to 70 with good effect, but do read up on the consequences of doing this.
    On some ESC's I have also set MOT_TCRV_ENABLE to false to disable the throttle curve to give better linearity to the motor speed.
  • I was wondering why you selected manual timing instead of auto, was there some instructions with the ESC's to work with those motors?
    It does look like an ESC problem, but note that the output of the throttle is not a linear representation of your throttle input.
    For instance, you will not get full throttle even with the stick at full, as there has to be some % left for the controller to still stabilise the craft.
    The main issue I see is this having to give it 20% throttle to get the ESC's to spin.
    In the radio calibration page what is the PWM range of your throttle?
    On your Tx what is the travel range for your throttle, -100% to 100%?
    Are there any sub trim settings? Anything else in the Tx that might be causing this?
    As an example, I fly all Hexa's from a single factory default Tx Acro setting. The only changes in the Tx was the mixing for flight modes.
  • What firmware have you loaded?
    What calibrations have you done?
    Can you post a log file?
    Providing more information allows for a more complete picture of what is happening.
