Hi
I have just assembled the Ardupilot Mega full kit and have started testing it, all seems OK using the latest Ardupilot Mega planner (downloaded today), I can see all movements of the sensors in AC2 Raw sensor screen, but when I go into the Radio tab I can only see movement of the radio on the left "Radio In" but no movement in "Radio Out". I am sure it is something simple (a bit like me) but anyone any ideas.
Cheers John
You have to put the throttle stick lower right during more than 2 secondes to arm the motors. Be careful when doing this, disconnect ESC signal feeds.
You'll only see outputs after you arm the motors.
Basically until the code is actually sending a signal to the outputs it won't show up in the planner.
Just remember, make sure you don't have the motors powered up (or have the props removed) while testing.
chris.
