  • After testing everthing I found that the 3D robotics power board was leaking battery voltage to the signal pin to motor 1. I cut the pin on the board and soldered the wire to pin. Everything is great now.
  • New info. This is my board from 3d Robotics. Checking with a ohm meter everything seems fine. But when I plug in a battery I have full 12V on top pin for motor one. All other pins read 0V. Is ths a bad board?
  • Try the motor and ESC directly connected to a radio (with the prop removed!). If it still doesn't work check the signal wire on the ESC. It could be something simple like a cold solder joint. If the wires check out it might be a bad ESC or motor.
