Obstacle avoidance using Infra Red Sensors
I have 4 infra red sensors which I plan to use for obstacle avoidance.. I want to edit the Arducopter 2.7.3 software in such a way that when an obstacle is detected, my quadcopter avoids it in either of the 4 directions..
How do I start ?
  • I'm keen on this two, but fundamental lack of electronic knowledge leaves me wondering if I can just simply chain these up in parallel to form a single, 360' sensor.
  • How did you connect the 4 sensors to the APM. Are you using APM 1 or 2?
  • Admin
    @Altaf,
    Take a look at the ArduRover code as JLN has added code to use a Sharp IR sensor in place of the sonar. I am attaching a copy of the ArduRover 2.20b code.
    TCIII
    APMrover220b_firmware.zip
    https://storage.ning.com/topology/rest/1.0/file/get/3692541217?profile=original
  • I am also interested in the obstacle avoidance via InfraRed sensors. And not just for horizontal, I think I might have at least one that looks up (to avoid hitting trees, ceiling, etc, OR when the vehicle is tilted because it is flying forward). Have you made any progress?
  • You would need to download the source code and a copy of the Arduino software.
    The Arduino software will allow you to edit, compile and upload your changes to your board.
