Hello. Today I've got a GPS module GTPA010 on MediaTek_V12 which was bough from diydrones.com some time ago.
Now I have some troubles. It has 6-pin h jst connector, but when i look at the bottom i can see 5outputs: GND, 5V, OUT, IN, EN. How can I know which wire from connector (which pin) suite each output. I don't know if the top red wire is GND or it is nothing, but the second black wire is GND. Can you help me?
Can I somehow check it with multimeter? How?
Does your multimeter have a continuity mode (makes a tone when you have a complete circuit like touching the probes together)? If yes you can put one probe on a pin on the connector or a wire and then touch each pad until you get a tone that indicates the wire goes to that pad. If it doesn't have a continuity mode use resistance mode and look at low resistance to indicate a wire is connected to a pad. Having a tone is much easier, though so you don't have to keep looking at the meter.
Piotr said:
Fuck, and now I'm not sure, cuz Michelle said smth different. I will try to check with multimeter, but don't know how to do it. I will figure out :P
Ray Anderson said:
No, I was stupid and pasted the wrong link apparently.
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&sou...
No worries, though I would test yourself to be sure. I am using mine with an arduino also but not using the cable - i soldered pins directly to the pads: http://imgur.com/a/FOrji
Yes gps out goes to arduino in (Rx)
Piotr said:
Thanks a lot, you are my hero !
To be sure, I need to connect Out to Rx in arduino?
Michelle C said:
I have that module but mine is v13. Testing with a multimeter gives :
red -> gnd
black-> 5v
yellow -> in
green -> out
blue -> gnd
white -> no connect
Maybe I'm stupid but can't find anything about the module connection in this link.
Ray Anderson said:
