One motor is not synchronize with other 3 motors
1. When the throttle is fully down three motors are spinning very slowly  and one motor doesn't spin. When raise the throttle a bit the 4th motor that was not running start to spin. Can someone advise what could be the problem?  I synchronize all motors as in the guide.
2. Is there a way when motors are armed and the throttle is down that the 4 motors will not start to spin?
  • Hope you solved your problem (long ago!)
    If not, the ESC calibration page of the on-line manual tells us that synchronization problems, including some motors starting to spin later than others, is an expected consequence of ESC mis-calibration.
    That was exactly my experience. All-new ESCs (4). "All-in-one" calibration (as per the manual page). Result was 2 motors spinning and 2 motors - nothing.
    So I manually calibrated the two 'dead' ESCs. Result - all 4 motors spinning, but one starting later and spinning much slower than the others.
    So, I manually re-calibrated all 4 ESCs and - problem gone.
    Moral (in this case) - don't 'mix' calibration procedures. And keep re-calibrating (as advised in the manual) if you have synch problems.
    George
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
