Parts List - Please Advise
I'm looking at putting together my first Quad, but seem to be going round in circles in choosing the parts.
I have been building / flying RC heli's for a few years now and have some programming, electronics and  micro controller experience so this project is going to be very exciting.
I started out looking at the AeroQuad Cyclone Frame because it can be configured so many ways, i.e. Y6 that may be more stable and a worthy upgrade later. However, its very heavy and very expensive so that has put me off.
Any help on the following would be appreciated, am I going in the correct direction? Are there any other parts I need to order?  Anything special I will need for flashing firmware or connecting the the HK flight controller? Would you go straight to the PoxHawk controller?
Kev
Project Purpose
1) Learning and having fun while building a steady flying drone!
2) Play with GPS for Positioning and Navigating to Waypoints.
       Is it posible to Geo Tag the waypoints loosly, i.e. fly through rather than be too precise?
3) Use an Arduino to monitor hardware (vibration, current, heat etc.)
4) Possibility to take learning to unprofessional FPV system - (just for more fun)
       Keep this in the back of my mind when building, however may need to start again then?
General Questions
1) What flight time would you expect to get from this (no payload)
2) Will the parts I have outlined below feed telemetry back to my laptop?
3) Will the parts I have outlined below allow my to update the flight path from my laptop?
4) Will the AMP 2.5 be OK or should I pay the extra for the PixHawk or another system?
4) I have learned everything a know about RC heli's from internet groups, are there goods groups available covering what I am trying to do here?
The shopping list (including backups):LinkOption 2 ($)Weight (g)Spare Part
Quad Frame (Including a few spares)
Are there better options available from HK?
I choose this as it looks like I could repair it with locally sourced parts and cheap enough to throw away if I want to move to a Y6 configuration later.
Hobbyking X666 Glass Fiber Quadcopter Frame 666mmLink [HK]17.48415
Hobbyking X666 Aluminum Square Booms (5pcs/bag)Link [HK]6X
Hobbyking X666 Glass Fiber Main Frame Bottom Plate (1pc/bag)Link [HK]4.69X
Hobbyking X525 V3 Glass Fiber Main Frame Top Plate (1pcs/bag)Link [HK]8.45X
Hobbyking X525 V3 Glass Fiber Main Frame Upper Plate (1pc/bag)Link [HK]4.25X
Hobbyking X525 V3 Glass Fiber Motor Mount (4pcs/bag)Link [HK]3.52X
Hobbyking X525 Glass Fiber Landing Gear (4pcs/bag)Link [HK]3.55X
Quad Frame Expansion to allow additional Parts
Woven Carbon Fiber Sheet 300x100 (1.0MM Thick) (UK Warehouse)Link [HK]13.15
Woven Carbon Fiber Sheet 300x100 (1.5MM Thick) (UK Warehouse)Link [HK]17.42
Electronics
5x Turnigy Multistar 30 Amp Multi-rotor Brushless ESC 2-4S (1 Spare)
Are there better options?
Link [HK]60.35116
5x D2830-11 1000kv Brushless Motor (1 Spare)
Link [HK]49.35208
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Flouro Yellow)
Are these the correct size for what I want?
How do you calculate this?
Link [HK]3.1530
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Black)
Link [HK]3.1530
Extension Wires20
Batteries
2x Zippy Nano-Tech 3S 2200mah (place in Parallel to provide 3S 4400mah)
Already have these from my 450 Heli's
Link [HK]0380
Flight Controller
HKPilot Mega V2.5 Flight Controller USB/GYRO/ACC/MAG/BARO
This is a Clone of the APM 2.5 system,  built in a compass which is not always the best idea.
Should I pay the extra for the PixHawk system instead? Or something better?
Link [HK]7617
Turnigy Mounting Box for HKPilot Mega V2.5 Flight Controller
The accuracy of a Barometer is effected by light and the above board is bare so must be covered.
Link [HK]631
UBLOX LEA-6H GPS Module w/Built-in Antenna 2.5m Accuracy V1.01
Will this work with the flight controller above?
Link [HK]51.8728
FPV 433Mhz Radio Telemetry Kit 100mW V1.1 (UK Legal)
I want to use the APM Autopilot Suite, will this kit be compatible?
Link [HK]31.5922
Tx / Rx
1x Spektrum DX8 (already have)018
1x Spektrum 8ch Rx (already have many kicking around)0
Laptop for Ground Control (to run APM Autopilot Suite)
Lenovo B570 Laptop0
Quad Fly Weight (g)1295
Project Cost (USD)$379.97
Project Cost (GBP)£231.78
Contingency Fund (GBP)£75.00
  • Just update the last lines
    Quad Fly Weight (g) 1295
    Project Cost (USD)         379.97
    Project Cost (GBP)         231.78
    Contingency Fund (GBP) 75.00
