Photogrammetry: Strange Question
This is kind of a strange question for this group, but here goes.
I want to use an old ArduPilot Mega 2.0 I had never used and I want to use it to capture images for photogrammetry from a manned aircraft.
So I would like to use the Mission Planner and have the APM2 trigger the camera and write the metadata for use in Pix4D.
Since a human will be flying the aircraft (following the mission planner routing) can I do this without defining a drone platform during setup?
Or can I just select something and ignore it as the servo commands will not go anywhere?
Any info, thoughts, comments welcome.
  • I've done this. You don't even need a flight plan, just set cam_trigg_dist to the gps distance you want. You can just set it up as a Plane, and ignore all the calibrations.
    • Thanks for your reply.
      - How did it work out for you? Get the results you wanted?
      - By using the Mission Planner helps with getting the desired resolution by defining the altitude and help define image overlap, no? Or how did you manage these parameters of the capture?
