  • Hello Addy/Moglos,
    After long time, I had left this project. Actually I am still struggling with the setup with flightgear and not able to find any help on net. I have spent day and dont want to leave it again incomplete this time. Please guys help me out.
    Now I am able to launch, flightgear with Rascal plane. But on ground it is very unstable. I yaws very badly so I tried to initalise it directly in air but again I am not able control it in manual mode. It rolls and then comes to ground. Not able to find what is the issue, I am using the latest version of flightgear should i change it back to flightgear 2.x version as mentioned in DIY drones website. Completely helpless on this.
    Do I have to change other configuration parameters like PID gains etc? Also I am using the older version of software V2.68 as mentioned in the website. Should I try with the latest version.
    • Did you ever get this solved? Seem to be having the same problem when I start the Rascal plane in air. Wondering what you did  or if you found anything else out.
  • Can someone please direct me to a place where I can look up what the purpose of all of these values are?  I apologize if I am posting in the wrong place I am new to forums in general.  Any help provided will be very helpful.  I am using  an x quadcopter with an arduopilot.  Thanks in advance!
    RC7_MAX,1497
    RC7_DZ,0
    SYSID_MYGCS,255
    SR0_EXTRA1,0
    STB_YAW_I,0
    WPNAV_LOIT_SPEED,400
    CIRCLE_RATE,5
    INS_MPU6K_FILTER,0
    SONAR_TYPE,0
    RC4_DZ,40
    OF_RLL_P,2.5
    RATE_PIT_D,0.004
    RC2_TRIM,1509
    SERIAL3_BAUD,57
    RSSI_PIN,-1
    THR_MAX,1000
    SYSID_THISMAV,1
    OF_PIT_I,0.5
    RC11_MIN,1100
    RC6_REV,1
    SR3_EXTRA1,0
    RC1_DZ,30
    RTL_ALT_FINAL,200
    ACRO_P,4.5
    MNT_RC_IN_PAN,0
    SR3_EXTRA3,0
    BATT_VOLT_PIN,13
    RATE_PIT_I,0.1
    MNT_NEUTRAL_X,0
    SR3_EXT_STAT,0
    FLTMODE3,0
    RC2_REV,1
    OF_RLL_I,0.5
    SCHED_DEBUG,0
    SR3_RAW_CTRL,0
    OF_PIT_IMAX,100
    ACRO_BAL_ROLL,200
    AHRS_TRIM_Z,0
    SR0_PARAMS,50
    SR3_PARAMS,0
    HLD_LAT_IMAX,3000
    RC10_DZ,0
    RC4_MIN,1113
    SR3_RAW_SENS,0
    RTL_LOIT_TIME,5000
    RC_SPEED,490
    MNT_STAB_PAN,0
    RC10_FUNCTION,0
    RC10_TRIM,1500
    SR0_EXTRA2,0
    RC11_REV,1
    FENCE_ENABLE,0
    RC4_MAX,1904
    RTL_ALT,1500
    RC10_MAX,1900
    LOITER_LAT_P,1
    AHRS_TRIM_Y,0.01
    MOT_TCRV_MIDPCT,52
    COMPASS_OFS_X,-53.542
    COMPASS_OFS_Y,-105.59
    COMPASS_OFS_Z,107.401
    FENCE_ALT_MAX,100
    RC8_MIN,1496
    RC11_TRIM,1500
    RC5_TRIM,1510
    LED_MODE,9
    MNT_ANGMAX_ROL,4500
    FS_GPS_ENABLE,1
    RATE_RLL_P,0.1
    FLTMODE5,0
    GND_ABS_PRESS,100583.4
    THR_ALT_P,1
    SR0_EXT_STAT,0
    STB_YAW_IMAX,800
    STB_RLL_P,4.4
    INAV_TC_Z,5
    RC7_REV,1
    THR_ACCEL_I,1.5
    RC1_MIN,1105
    MOT_TCRV_MAXPCT,93
    FRAME,1
    MNT_RETRACT_Z,0
    MNT_RETRACT_X,0
    MNT_RETRACT_Y,0
    FS_BATT_ENABLE,0
    MNT_RC_IN_TILT,0
    COMPASS_MOT_Y,0
    SR0_EXTRA3,0
    RC11_DZ,0
    RC11_MAX,1900
    THR_ALT_I,0
    RC6_FUNCTION,0
    BATT_CURR_PIN,12
    LOITER_LON_D,0
    STB_RLL_I,0
    FENCE_TYPE,3
    TRIM_THROTTLE,544
    SR0_RAW_CTRL,0
    WP_YAW_BEHAVIOR,2
    RC5_MAX,1910
    MNT_JSTICK_SPD,0
    WP_INDEX,0
    MNT_RC_IN_ROLL,0
    RC2_DZ,30
    CAM_SERVO_OFF,1100
    COMPASS_ORIENT,0
    CIRCLE_RADIUS,10
    RATE_RLL_IMAX,500
    TELEM_DELAY,0
    STB_YAW_P,4.5
    LOITER_LON_I,0.5
    RC7_FUNCTION,0
    RATE_YAW_D,0
    RC8_TRIM,1497
    RC4_REV,1
    RC3_TRIM,1501
    RC1_REV,1
    TOY_RATE,1
    LOW_VOLT,10.5
    LOITER_LON_IMAX,400
    FENCE_RADIUS,150
    SUPER_SIMPLE,0
    FLOW_ENABLE,0
    RC7_MIN,1496
    SYSID_SW_TYPE,10
    ARMING_CHECK,1
    RC11_FUNCTION,0
    THR_ACC_ENABLE,1
    BATT_MONITOR,3
    CAM_TRIGG_TYPE,0
    RC6_MIN,1496
    SR3_RC_CHAN,0
    FS_THR_VALUE,1050
    FS_THR_ENABLE,1
    PILOT_VELZ_MAX,250
    LOG_BITMASK,830
    OF_PIT_P,2.5
    FLTMODE4,5
    ACRO_TRAINER,1
    SR3_EXTRA2,0
    THR_ACCEL_IMAX,500
    MNT_STAB_ROLL,0
    COMPASS_AUTODEC,1
    MNT_CONTROL_X,0
    MNT_ANGMAX_TIL,4500
    MNT_CONTROL_Z,0
    RC8_FUNCTION,0
    RATE_YAW_P,0.2
    THR_MIN,130
    WPNAV_SPEED,400
    RC2_MAX,1913
    RC8_REV,1
    RC3_MIN,1098
    MNT_ANGMIN_PAN,-4500
    MNT_ANGMIN_ROL,-4500
    AHRS_GPS_USE,1
    RATE_YAW_I,0.02
    THR_MID,500
    MNT_ANGMAX_PAN,4500
    RC6_DZ,0
    RATE_RLL_D,0.004
    MNT_NEUTRAL_Z,0
    STB_RLL_IMAX,800
    AHRS_GPS_GAIN,1
    AMP_PER_VOLT,18.002
    OF_RLL_D,0.12
    STB_PIT_P,4.4
    CH7_OPT,0
    VOLT_DIVIDER,10.24
    THR_RATE_I,0
    RC3_DZ,30
    RC5_REV,1
    AHRS_GPS_MINSATS,6
    FLTMODE6,0
    SR0_POSITION,0
    THR_ACCEL_P,0.5
    COMPASS_USE,1
    SONAR_GAIN,0.2
    COMPASS_DEC,0
    AHRS_WIND_MAX,0
    MNT_MODE,0
    RC8_DZ,0
    WP_TOTAL,1
    STB_PIT_I,0
    RC5_MIN,1107
    MAG_ENABLE,1
    THR_RATE_IMAX,300
    WPNAV_RADIUS,200
    RC5_FUNCTION,0
    SYSID_SW_MREV,120
    SONAR_ENABLE,0
    FLTMODE2,0
    INS_GYROFFS_X,0.026
    INS_GYROFFS_Y,-0.045
    INS_GYROFFS_Z,-0.002
    THR_ACCEL_D,0
    LOITER_LAT_D,0
    THR_RATE_P,5
    FS_GCS_ENABLE,0
    WPNAV_ACCEL,100
    RC1_MAX,1911
    RATE_PIT_P,0.1
    AHRS_COMP_BETA,0.1
    WPNAV_SPEED_UP,250
    AHRS_ORIENTATION,0
    RC3_MAX,1917
    RATE_RLL_I,0.1
    OF_RLL_IMAX,100
    CH8_OPT,0
    INS_ACCOFFS_Z,0.337
    INS_ACCOFFS_Y,0.226
    INS_ACCOFFS_X,-0.116
    LOITER_LAT_I,0.5
    TUNE,0
    TUNE_LOW,0
    ESC,0
    SR0_RC_CHAN,0
    AHRS_RP_P,0.1
    OF_PIT_D,0.12
    AHRS_TRIM_X,0.005
    RC4_TRIM,1509
    RC6_MAX,1497
    RC10_MIN,1100
    RC10_REV,1
    RATE_YAW_IMAX,800
    FENCE_ACTION,1
    RC5_DZ,0
    SR3_POSITION,0
    MNT_ANGMIN_TIL,-4500
    FLTMODE1,6
    LOITER_LAT_IMAX,400
    RC3_REV,1
    MNT_STAB_TILT,0
    RATE_PIT_IMAX,500
    CAM_SERVO_ON,1300
    HLD_LON_IMAX,3000
    LOITER_LON_P,1
    WPNAV_SPEED_DN,150
    BATT_CAPACITY,5000
    STB_PIT_IMAX,800
    RC8_MAX,1497
    LAND_SPEED,50
    MNT_NEUTRAL_Y,0
    SIMPLE,8
    INS_ACCSCAL_X,1.005
    INAV_TC_XY,2.5
    COMPASS_MOTCT,0
    HLD_LON_I,0
    COMPASS_LEARN,0
    AXIS_ENABLE,1
    HLD_LAT_I,0
    RC6_TRIM,1497
    RC2_MIN,1111
    SR0_RAW_SENS,0
    ACRO_BAL_PITCH,200
    THR_ALT_IMAX,300
    AHRS_YAW_P,0.1
    HLD_LON_P,0.4
    THR_RATE_D,0
    MOT_TCRV_ENABLE,1
    RC7_TRIM,1497
    HLD_LAT_P,0.4
    CAM_DURATION,10
    MNT_CONTROL_Y,0
    TUNE_HIGH,1000
    RC1_TRIM,1512
    COMPASS_MOT_Z,0
    COMPASS_MOT_X,0
    INS_ACCSCAL_Y,0.995
    INS_ACCSCAL_Z,0.99
    INS_PRODUCT_ID,88
    GND_TEMP,32.67
  • Dear friends,
    I want to do HIL simulation with flightgear and have following setup.
    GCS 1.2.76, Ardupilot 2.5 and Flightgear 2.10.
    I have followed exactly the steps given in the following link.
    http://plane.ardupilot.com/wiki/flightgear/
    but not able to get everything working. I am facing two main issues.
    1. I am not getting Rascal airplane when I launch flightgear from GCS interface. I am not able to find what is missing.
    2. With Cessna airplane, I am able to fly manually but as soon as I put in auto mode, throttle goes to zero and aircraft starts     diving from the sky. I am not able to find what could be the probable reasons for this.
    Please friends help me out as I am really struggling with these issues.
  • 300km
    Hi Addy,
    How do you select other models? I'm using the method at http://code.google.com/p/ardupilot-mega/wiki/FlightGear and I can fly missions OK with the default Cessna, but I don't know how to choose the Rascal model.
  • Rascal is small rc airplane and there are models available for simulators.
  • yeah HIL works fine. i did this for 2 models on flightgear. and the code works absolutely fine. if u need any further help please feel free to ask.
  • Hi, did you ever get flightgear hil working, I seemed to have it working initially, but
    Are a few pod changes, and now it keeps crashing, using the default Cessna 172 aircraft,
    Is the rascal a standard aircraft?
