250 Quad with Pixfalcon help
I converted my ZMR250 from a Naze 32 to a Pixfalcon. I got everything setup and vibrations looks fine.
I then did a auto-tune on the Roll axis and would like to know if it is normal for a small quad or should I be concerned with the low values.
Stabilize Roll = 4,873756
Roll P = 0,03859347
Roll I = 0,03859347
Roll D = 0,001254361
Imax = 0,444
Filt = 20,000
Firmware Ver. 3.4.6
I did try to auto-tune the Pitch axes as well. But the quad just fell out of the air close to the end of the cycle because of a dodgy battery.
I got new batteries and would like to attempt autotune again. I just need some reassurance.
Henry
  • Hi , I posted it in the Copter 3.5
    Copter 3.5
    Discussions and support for Copter 3.5
  • Hi Henry,
    thanks to yours post here, I see the exact same problem I have!
    I suggest you to join the ardupilot community on the new forum at https://discuss.ardupilot.org/
    Please remake this post there and I'll join it with my same experience, I need to fix it too asap :) ...with no wind the little quad its perfectly stable, but as soon as a little breeze comes in its going drunk and not stable anymore :(
    Lets work on it Arducopter for little quad!
    ArduPilot Discourse
    ArduPilot Discussion Server
  • Hi I upgraded to Ver 3.5
    Here is a flight log if someone can look at it and point out problem areas please.
    Did not use autotune. I used PID's that flew OK and based on other users settings. I flies ok but seems that the slightest wind make it twitch. In no wind it is very stable
    2017-07-30 09-15-25.bin
    2016-11-27 11-06-06.tlog
  • No 250 pilots out there????!!!!!!!
    I am a bit worried because it can not be set that low under Extended Configuration. You can do it under the full parameter settings but you get a warning that it is out of range.
