Pixhawk 2.1 Return to Nearest Waypoint?
Hi everyone,
Is there a feature in the Pixhawk 2.1 autopilot system that, in the event of a radio failsafe or low voltage failsafe, will command the drone to return to a previously set waypoint and land there for recovery? All input/ideas are very much appreciated.
  • Thanks Marc, that's exactly what I had in mind.
    Hi everyone, Is there a feature in the Pixhawk 2.1 autopilot system that, in the event of a radio failsafe or low voltage failsafe, will command the…
  • Hi Marc.
    for the Rally Point alt on VTOL Plane, can we command the plane to land using Q_xxx mode on much lower alt compare with Home default Alt?
    for example: the VTOL plane take off from 200 AGL and in case of RTL should be landing on the rally point that is lower AGL altitude i.e 100 AGL
  • Hello,
    See Rally Point feature,
    http://ardupilot.org/copter/docs/common-rally-points.html#overview
    Marc
    Rally Points — Copter documentation
