I just received a 3DR version1 Radio set to connect to my Pixhawk controller. Both the Pixhawk and the 3DR radio have a 6 pin connecter on them, but it not a straight pass through like the one used with the version 2 3DR. The APMcopter site has a wiring layout to use the version 1 3DR with the Pixhawk, and it is not a pass through like V2 3DR uses. 3Drobits does not make a cable I can use. Those wires are small to splice, but I can do it needed. Has any one done this and does it work.
This is a reply to my (Pixhawk 3DR v1 Cable). I took a six pin cable and cut it in half, using the wiring layout from APMcopter 3DR section I hacked a new six pin cable . I connected the HobbyKing 3DR radios and all works great
You got pictures on how you did that?
