Pixhawk & Analog Airspeed sensor
Hello,
I'm helping someone install an analog airspeed sensor with the pixhawk, the wiki says:
The “airspeed” pin 15 is located on a 3 pin DF13 connector on the Pixhawk board.
This pin can take voltages up to 6.6V (it has an internal voltage divider).
The analog airspeed sensor does not have a DF13 connector, but instead a servo cable. So - the only way to connect the analog sensor is to butcher a DF13 cable and splice it to the servo cable? that seems odd! No way to connect the sensor to one of the normal servo style connectors on the pixhawk?
Thanks - any help would be appreciated.
  • I've used analog air speed sensors on two different planes with Pixhawks. They work perfect. I sacrificed an I2C cable by cutting off the 4th pin. Then followed the instructions here: http://plane.ardupilot.com/wiki/airspeed/#analog_airspeed_sensor
    -Brian
    • Also using analog airspeed sensor on APM, sufficiently stable (to 1 or 2 km/h). Don't forget that on every startup it has to be covered and it will calibrate itself for "zero" wind speed.
