Pixhawk and RSSI (Digital) From FrSky or others
I have been searching for any new posts related to the topic of PWM RSSI such as what Orange LRS outputs, FrSky, I think EZUHF and probaly many more. I know on Pixhawk.org it explains that is has PWM Rssi input. Will this ever be implemented on Copter or Plane ? (or is it and I just can't figure it out?)
I know you can go RSSI over channel but a lot of receivers do not let you do that. Is there a limitation I am unaware of or just not enough demand to support the new code development?
I know you can buy a filter to go to analog but that seems to be going backawards not forwards with the tech.
Thanks for your input.
  • Hi, have you solved this problem? I am using Dragonlink V2 with the multicopter version of the receiver. It has an RSSI pin and also you can configure digital rssi on one of the channels. but i can not get the value on pixhawk
    thanks in advance
