  • not in current release, but in next release, there's a paramter SAFETYENABLE, if you set it to 0 , you don't need a switch - if you build from source, it's there..
    • Yes you're right, thank you so much.That would be a great help in the future :). For now,  I'm still having problems in terms of arming. The peripherals connected were GPS, compass, buzzer, and the safety switch. I still can't do the Radio Calibration since I have problems on the connectors/wires. Have you tried arming it without calibrating? I can't, I just want to ask if you've tried it successfully or not, because apm can do arming without Radio Calibration.
      Thanks,
      Cherry
      • Arming requires at least throttle ( in case mode 2) and yaw to be in certain position, without radio calibration, that is not possible.
        • Oh I see, thank you so much! :) I'll try arming it if my RC problems will be fixed already.
          Have a nice day,
          Cherry
