Pixhawk motors stop
This is my first time I have been using a drone. I'm using a quadcopter with a pixhawk running PX4 firmware. I'm testing my drone without props connected to a power supply. When I increase the throttle the motors start spinning normally but when I hold the throttle for a time on the same level, some motors stop spinning. But when I change the pitch or roll, they start spinning again. Is this normal? I'm just a beginner.
Thanks!
  • Also depending on what flight mode you are in, the controller is expecting to see some movement and if it is not, it gets "confused" and you will have weird behavior of motors.
    Try same experiment and move the quad around so the motors react to the angle changes.
    If you select acro mode you should be ok with it sitting still since the flight controller is not trying to constantly perform "auto level" calculations.
  • Without more detail I can only make one suggestion:
    With propellers disconnected there is very little resistance torque so the motors spin up very easily. Any slight differences in the ESC calibrations can cause some motors to stop near to throttle minimum.
    You may find that with props connected it just works!
DIY Robocars via Twitter
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
yesterday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
yesterday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
yesterday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
Aug 28
