Pixhawk PWM input for RSSI (EZUHF)
Gents I need your help.
I recently upgraded one of my 2.6APM powered quads to a Pixhawk.  One of the reasons I went ahead and did this is because the Pixhawk is supposed to take PWM RSSI signals directly (into the Sbus port aka Pin 103) and I could ditch my PWM to analog conversion circuit is used in my APM.
I have verified that my EZUHF receiver is outputting RSSI in PWM form on one of the channels. (it will move a servo appropriately when the RF gets weak or disappears... and it worked fine for the APM as an RSSI input via a PWM to analog conversion circuit)
And, I have hooked up the PWM RSSI output to the Sbus port (pin 103).... it does nothing.  Shows zero RSSI on the OSD no matter what.
I can't find any useful description of how to configure this in the wiki, mission planner or this site.
How do you make a Pixhawk show RSSI from a PWM input on pin 103 as its advertised?
Thanks for your help.
Steve
      • This is for a Pixhawk setup.
        Edit: For the APM I connected ch8 from EzUHF directly to the APM, slightly different setup. And slightly different setup in Mission Planner as well. As I remember, ME was excatly the same (maybe some different min/max values for RSSI min/max albeit).
  • ArduPlane:
    Got the EZUHF RSSI/Link to work with my Skywalker APM 2.6 plane.
    The RSSI has inverted values and extra percent sign problem but it works!
    What I used:
    EZUHF TX/RX firmware v1.50
    ImmersionRC Config Tool v1.40
    MinimOSD firmware Extra Plane v2.4 Pre-Release r719
    Config Tool for MinimOSD v2.4 Pre-Release r727
    No settings needed to be changed in the APM Mission Planner
    RSSI MIN/MAX 993/1650
    Link Quality MIN/MAX 1074/1794
    • trying to set this up and I find when I assign EZUHF LQ to channel 8 I lose my flight mode selection
      Using the latest APM plane on an APM 2.6
      Any clues Gents, this is driving me spare!
      Ross
      • I moved my flight modes to a different channel.
        Look a about time code 2:17 in this video for the schematic and explanation:
        https://www.youtube.com/watch?v=rh7-D96FIK0
        • Thanks David
          I have watched your Video a couple of times, very well presented
          I am using CPPM and want to keep it that way
          My problem is I cannot figure how to switch my Flight mode select channel to anything other than Channel 8 (I'm using Arduplane 3.2)
          I note in your schematic you use channel 6, how did you change that from what appears to be the default of channel 8
          To confuse the issue more the current setup wiki says to use channel 5 which doesn't work for me
          • I changed the flight mode channel input from the default 8 to 6 in the mission planner and then wrote the settings to the APM.
            • for the nth time I looked and found it
              all good now, many thanks David
              • Oh! well I am glad you found what you needed.
                You would think it would be on the flight mode screen, right? But noooooo way.
                Just to recap for others, I changed the flight mode channel under config/tuning under the full parameter list. Look for FLTMODE_CH. (APM must be connected first)
                Where did you find it?
                • I had looked in Mission Planned a few times with no luck, it must have been sticking in my face. I remember looking at the param's at the four major flight controls assignments which are the very next ones. DOH!
                  Funny, the first time I looked at the list in the wiki I found it straight up
                  Must be dyslexic or something :)
                  Thanks again for your help
            • Got That
              Please forgive my stupidity but I am asking how to do that
              What parameter are you changing and where do I find it?
sam liked Jimmy Oliver's profile
Aug 25
Mike Whitney liked Mike Whitney's profile
Jul 19
Abdulatif Tlaib liked Ryan's profile
Jun 24
