Pixhawk PWM input for RSSI (EZUHF)
Gents I need your help.
I recently upgraded one of my 2.6APM powered quads to a Pixhawk.  One of the reasons I went ahead and did this is because the Pixhawk is supposed to take PWM RSSI signals directly (into the Sbus port aka Pin 103) and I could ditch my PWM to analog conversion circuit is used in my APM.
I have verified that my EZUHF receiver is outputting RSSI in PWM form on one of the channels. (it will move a servo appropriately when the RF gets weak or disappears... and it worked fine for the APM as an RSSI input via a PWM to analog conversion circuit)
And, I have hooked up the PWM RSSI output to the Sbus port (pin 103).... it does nothing.  Shows zero RSSI on the OSD no matter what.
I can't find any useful description of how to configure this in the wiki, mission planner or this site.
How do you make a Pixhawk show RSSI from a PWM input on pin 103 as its advertised?
Thanks for your help.
Steve
      • This is for a Pixhawk setup.
        Edit: For the APM I connected ch8 from EzUHF directly to the APM, slightly different setup. And slightly different setup in Mission Planner as well. As I remember, ME was excatly the same (maybe some different min/max values for RSSI min/max albeit).
  • ArduPlane:
    Got the EZUHF RSSI/Link to work with my Skywalker APM 2.6 plane.
    The RSSI has inverted values and extra percent sign problem but it works!
    What I used:
    EZUHF TX/RX firmware v1.50
    ImmersionRC Config Tool v1.40
    MinimOSD firmware Extra Plane v2.4 Pre-Release r719
    Config Tool for MinimOSD v2.4 Pre-Release r727
    No settings needed to be changed in the APM Mission Planner
    RSSI MIN/MAX 993/1650
    Link Quality MIN/MAX 1074/1794
    • trying to set this up and I find when I assign EZUHF LQ to channel 8 I lose my flight mode selection
      Using the latest APM plane on an APM 2.6
      Any clues Gents, this is driving me spare!
      Ross
      • I moved my flight modes to a different channel.
        Look a about time code 2:17 in this video for the schematic and explanation:
        https://www.youtube.com/watch?v=rh7-D96FIK0
        • Thanks David
          I have watched your Video a couple of times, very well presented
          I am using CPPM and want to keep it that way
          My problem is I cannot figure how to switch my Flight mode select channel to anything other than Channel 8 (I'm using Arduplane 3.2)
          I note in your schematic you use channel 6, how did you change that from what appears to be the default of channel 8
          To confuse the issue more the current setup wiki says to use channel 5 which doesn't work for me
          • I changed the flight mode channel input from the default 8 to 6 in the mission planner and then wrote the settings to the APM.
            • for the nth time I looked and found it
              all good now, many thanks David
              • Oh! well I am glad you found what you needed.
                You would think it would be on the flight mode screen, right? But noooooo way.
                Just to recap for others, I changed the flight mode channel under config/tuning under the full parameter list. Look for FLTMODE_CH. (APM must be connected first)
                Where did you find it?
                • I had looked in Mission Planned a few times with no luck, it must have been sticking in my face. I remember looking at the param's at the four major flight controls assignments which are the very next ones. DOH!
                  Funny, the first time I looked at the list in the wiki I found it straight up
                  Must be dyslexic or something :)
                  Thanks again for your help
            • Got That
              Please forgive my stupidity but I am asking how to do that
              What parameter are you changing and where do I find it?
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
