Gents I need your help.
I recently upgraded one of my 2.6APM powered quads to a Pixhawk. One of the reasons I went ahead and did this is because the Pixhawk is supposed to take PWM RSSI signals directly (into the Sbus port aka Pin 103) and I could ditch my PWM to analog conversion circuit is used in my APM.
I have verified that my EZUHF receiver is outputting RSSI in PWM form on one of the channels. (it will move a servo appropriately when the RF gets weak or disappears... and it worked fine for the APM as an RSSI input via a PWM to analog conversion circuit)
And, I have hooked up the PWM RSSI output to the Sbus port (pin 103).... it does nothing. Shows zero RSSI on the OSD no matter what.
I can't find any useful description of how to configure this in the wiki, mission planner or this site.
How do you make a Pixhawk show RSSI from a PWM input on pin 103 as its advertised?
Thanks for your help.
Steve
Mark,
There a couple of "gotcha's" in the setup.
1) this works with 2.4r727... not the earlier releases
2) despite the ability to select different channels the minim OSD software only works with channel 8. (I think this is where your problem is)
3) I feed the PPM sum stream to the pixhawk, not individual channels. I suspect it will still work with individual channels but my setups are all via a sum stream...
There is nothing you need to do in mission planner to make this work.
I suggest setting the ezuhf signal quality to channel 8 and you will be good to go (other than calibrating it.)
A couple other suggestions... I prefer signal quality to RSSI because it is possible to have really strong signal strength but poor signal quality... this happens when you have things like the camera putting out noise on the 433MHz band.
To find zero and 100% set the minimosd to raw first and write down the numbers that appear when you switch the transmitter on and off... this will give you the figures to calibrate full and null signal... then go back into minim OSD put those figures in and remove the raw number switch...
Sorry for the frustration on this, but it can be made to work
MP1
Thanks for the tip, (I set ch8 to output RSSI, which it is doing), but I don't see how to tell the MinimOSD to read ch8 as the RSSI channel in the config tool.
I am running 2.3.0.8 minimextra config tool and version 2.3 copter in my quad.
Which screen do you find the RSSI channel selection in the config tool? I don't see it.
What setting if any do i need to make in MP?
Some context for my post above from the Pixhawk overview.
Virtual Pin 102: Servo power rail voltage. This is an internal measurement of the servo rail voltage made by the IO board within the Pixhawk. It has 3:1 scaling, allowing it to measure up to 9.9V.
Virtual Pin 103: RSSI (Received Signal Strength Input) input pin voltage (SBus connector output pin). This is the voltage measured by the RSSI input pin on the SBUS-out connector (the bottom pin of the 2nd last servo connector on the 14 connector servo rail). Can alternatively serve as SBus out but not yet implemented.
per the pixhawk overview
Steve
1
2
3
of 3 Next
