Pixhawk (PX4) for Jet engine powered UAV
I'm a student researcher working on a jet engine powered UAV. The task is to control the flight using pixhawk autopilot.
I have done few HIL simulations with my custom built aircraft inside X-Plane and customized gain parameters in pixhawk. The roll and pitch axis seems stabilized but since the airspeed I'm cruising at is around 180mph, I need some help/info regarding the maximum airspeed which can be set in pixhawk's TECS control. In the parameter reference guide the maximum value which can be set is 40m/s which is the stall speed of my aircraft. This will fail Altitude Control to work and possibly auto-take off and landing.
Does this mean that pixhawk is not capable to flying a jet engine or can we somehow tweak this limit from inside? Also, is it feasible to use pixhawk for such aircraft?
Regards.
  • It still does not answer my concerns. Generally speaking, is Pixhawk advised to use on an RC jet flying at 400mph for autonomous control?
  • I am trying to use SITL but facing few errors. I'm following the entire guide on how to use X-Plane with SITL. But it seems that mission planner isn't connecting to simulator. Following are the coonection parameters
    127.0.0.1 local port
    sim to pc 49000
    pc to sim 49001
    https://storage.ning.com/topology/rest/1.0/file/get/3702271108?profile=original
  • Thanks Andre.
    Great work in your video. Guess I'll have to flash pixhawk with ardupilot stack.
  • the parameter ref. guide often mention the "typical" range of settings, not the absolute limits.
    check out https://www.youtube.com/watch?v=llRii8hmG1M  , I'll answer you question  :)
