Hello, I have 2 drones.. both DJI F550. Drone #1 uses Naza Lite controller and works great!
My second drone is controlled by a Pixhawk.
Pixhawk
OPTO 30A ESC
DJI 2212 motors
4S battery
Spectrum DX9 transmitter
Spectrum AR8000 receiver
3DR PPM Encoder
Problem #1
I now understand that the OPTO 30A ESCs cannot be calibrated. However, my PIXHAWK seems to be 'stuck' in ESC calibration mode. On boot, the LED blinks fast red/blue/yellow. When I push the safety button, I can throttle up and down and the motors respond. When I cut throttle to zero and turn the pixhawk off, the next time I power it, it appears to be back in calibration mode.
Problem #2 (what got me in to Problem #1)
Set up the Pixhawk and went for my first flight... on arm, the motors spin slowly, when I throttle up the motors increase RPMs but only by a little bit. At max throttle, there is not enough RPM to lift the craft. However, at any throttle setting (except idle), when I push on any other stick (elevator, roll, or even rudder) the (some?) motors increase RPM significantly (I believe they are attempting to respond to the control requests). Still there is not enough lift to get the craft off the ground, but you can see it leaning/attempting to roll or pitch. Someone suggested that I calibrate the ESCs... I followed the instructions on how to do that, but since the 30A OPTO ESCs cannot be calibrated, that didn't seem to help. And now I'm somehow stuck in calibration mode on the Pixhawk.
The motors/escs are good as when I connect them directly to the output of the RC receiver, they work perfectly.
Help! Any thoughts/comments welcome!
Chris
I'm used to the Mission Planer autonomous program to make my flight, and use for my planer Droid tablet field ... I still use these control programs? if I install the firmware QGroudControl ... and another question: as modified PID?
