Hi
I am building a new quadcopter but pixhawk fails to arm. Here is what I have done till now
1. Connected radio and esc to pixhawk.
2. connected a independent bec to output rails for power. Didn't connect pixhawk power module because I don't have the right connection with me.
3. calibrated radio in QGroundControl. All good.
4. tried to calibrate ESC by recommended all in one method. No response from pixhawk. I guess it never goes into ESC calibration mode.
5 Gave up on all in one calibration, by passed pixhawk and connected servos directly to reciever's channel 3. Did calibration one by one using this method.
6 reconnection reciever and servos to pixhawk again.
No response to throttle. Tried disable switch nothing. blue led will keep flashing. If I do a long press of disable switch, its led goes into quick flashing.
Does any of it sound familiar. I am out of options.
Thanks Dan,
But I got it to fly without GPS. Problem was I didn't know that we have to hold the throttle down and to right for about 3seconds to arm the quad. Newbie problem. I haven't ordered a GPS unit yet. As far as I know Pixhawk has onboard compass. I even calibrated it.
Now I have another problem. My copter always drifts on yaw whenever I move pitch, pitch also changes but there is a measurable effect on yaw also.
If I pitch forward there is a small movement on yaw towards left and if I pitch backward the yaw movement is towards right. I have been searching with little luck. What could be the problem, where do I look.
This is the only hint that I have found till now.
http://copter.ardupilot.com/wiki/troubleshooting-2/#The_quad_always...
according to this, it will be alright after a few flights. Or may be I understood it wrong.
This seems to be another helpful pointer haven't tried it yet.
http://diydrones.com/forum/topics/ac3-1-rc5-yaw-issue
Well my problem turned out to be another total noob problem. My RC Tx had channel 2 (pitch) and channel 4 (yaw) mixed. They were moving with each other. Nothing to do with pixhawk. Will test in the morning.
Hi Dan,
Crash can damage the frame. It may throw off the center of gravity of the copter or worse introduce a lot of vibration. I have had both problems and they can be very irritating. May be your issue is linked to these problems as you mentioned that problem started after crash.
Pritam
