PixRacer with Ardupilot
This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens.  Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
3691274249?profile=original
  • Nice option, another one is a X 2.1 f board if fit.
  • In the blog post on the Convergence, I measured 168Hz for the FrSky converter.
    That was independent of the value for parameter SERIAL_SBUS_RATE, which defaults to 50Hz.
    If you have an oscilloscope or logic analyzer you should check what you're actually getting. Yours might behave differently due to firmware changes. Here's the point in the PR log where someone else thought he was seeing 50Hz: https://github.com/ArduPilot/ardupilot/pull/7270#issuecomment-34734...
    add library AP_SBusOut by kd0aij · Pull Request #7270 · ArduPilot/ardupilot
    supersedes #6794 Adds support for SBUS serial output in AP_HAL for all vehicle types. This PR implements the UARTDriver configure_parity and set_st…
  • Hi Mark,
    Ah gotcha regarding the frame rate. I just purchased the FrSky 4 channel one you suggested, so we'll see how we go with that. Any idea of its frame rate?
  • That looks good, too. Beware that some sbus to pwm converters will output frame rates > 50Hz, which might be a problem with analog servos. If you're using ESCs or digital servos, that's OK.
  • Also this: https://hobbyking.com/en_us/sbd4-4-channel-s-bus-decoder.html
    SBD4 4-Channel S.BUS Decoder
  • Glad you like it. I just noticed that there's now a very tiny single channel converter from FrSky: https://alofthobbies.com/frsky-sd1-sbus-converter.html
    Of course, without the pins and wrapper, the 4 channel one is also pretty small.
    FrSky SD1 SBUS Converter
    A compact and easy to use SBUS decoder to convert any conventional servo to an SBUS compatible servo.  This decoder converts a single SBUS channel to…
  • Wow, that's fantastic, Mark!
    Thanks so much. I only need two extra channels, and space is so limited. I need to get a very tiny converter, but this is great :)
  • you could use Sbus and a PWM converter as described here: https://discuss.ardupilot.org/t/e-flite-convergence-with-pixracer-a...
    Sbus supports up to 16 channels, and there are both 4 and 8 channel sbus to PWM converters on the market. So using one 8 channel converter would give you a total of 14 servo outputs.
    E-Flite Convergence with PixRacer and SBUS output
    Previous conversions of the Convergence to ArduPilot have used the Pixhawk1 flight controller (E-flight converge default file, E-flight Convergence d…
  • Is there any way at all that the PixRacer could be miraculously transformed such that it'll handle 8 ESC signals? I need something small for a coax octocopter that will a) run ArduCopter and b) fit the 30.5mm x 30.5mm (hole centres) board format.
    I'd be most grateful for any suggestions / advice etc.
  • The PixRacer does not have an analog input pin dedicated to airspeed input. I use the MS4525 and MS5525 digital sensors on I2C instead.
    Juan C Ricardo said:
    Hi guys:
    Anyone knows here if I can wire an analog speed sensor to pixracer ?
    regards and thanks in advance !
    jc
DIY Drones via Twitter
RT @chr1sa: After more than a year of only virtual races, @DIYRobocars returns to the newly renovated @circuitlaunch on May 22 for the resu…
22 hours ago
DIY Robocars via Twitter
RT @DAVGtech: And now available with LiDAR 🔥 https://twitter.com/Heavy02011/status/1381137016381964293
22 hours ago
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #9 - #ParkingLotNerds #thunderhillracetrack, CA Join us for the next race April 24th,…
22 hours ago
RT @DWalmroth: Weather's finally cooperating, looking forward to racing 1:10 scale autonomous cars outdoors again! @diyrobocars, @NVIDIAEm…
Wednesday
RT @AIDRI_: I finally succeeded in optimizing the trajectory and speed of a car on a #racetrack. Next step: implement a 2d controller and…
Wednesday
@jetdillo @circuitlaunch Actually the second *in person* event in a year. We do virtual races every month
Apr 2
Update: we're moving it back one day to Sunday (the 4th) at 11:00am instead
Apr 2
@GrantEMoe @circuitlaunch Update: we're doing it on Sunday (4th) at 11:00am instead
Apr 2
Laurie J. Troy liked Jasper Kueppers's profile
Apr 1
RT @chr1sa: Maybe we should have a mini @DIYRobocars race in our lower school's playground https://t.co/xLFeua1R6X
Mar 29
If anybody wants to join us for an informal outdoors hack/race we're going to be meeting at the @CircuitLaunch park… https://twitter.com/i/web/status/1375907409223249923
Mar 27
RT @SmallpixelCar: Ready to reopen, innovation has to continue. Inside/outside, LiDAR/GPS, race/delivery https://t.co/jpmvttoHEd
Mar 26
RT @DAVGtech: By far best race yet! Congratulations to the winner @Heavy02011 🥇🏆🍾👏👏👏 @diyrobocars @donkey_car @NVIDIAEmbedded https://t.co/…
Mar 20
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #8 - #ParkingLotNerds ⁦@DAVGtech⁩ ⁦@DWalmroth⁩ ⁦@OttawaAVGroup⁩ - join us tomorrow h…
Mar 20
RT @mrpollo: 11 years ago, the pxIMU was announced to the world on @DIYDrones, and it changed the life of many (mine included). The followi…
Mar 18
RT @ishcahealth: This is awesome! ☘️ @DroneDJ @DIYDrones @WorkerDrones @DroneMedia_UK @dublinaviation https://twitter.com/media_ireland/status/1372077878536462336
Mar 18
