This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens. Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
There is a lengthy thread at RCGroups here.gervais is active on the thread.
PhillipK and I spent some time just now trying to get the ESP wifi board working. I thought that it would simply be a matter of setting a few parameters (i.e. SERIALX_BAUD 921, BRD_SERX_RTSCTS 0 where "X" is some number from 1 to 4) but it seems that's not the case. Try as I might I, like others here, couldn't get the board working.
It seems the serial port is on device "/dev/ttyS0" (I'm writing it here perhaps mostly so I don't forget this piece of info).
So, there's definitely a problem and we will sort it out. Normally I'd jump on it immediately but both Tridge and I are tied up for the next 2 days or so. .. so it's going to take us a few days to sort it out but we will! I'm pretty sure this will lead to a Copter-3.3.5 release once we've confirmed the fix.
So sorry for the troubles and delay!
Randy...do you know what's up with the safety button light staying solid an not being able to go into all at once ESC calibration?
Just an idea... have you tried to set the BRD_SAFETYENABLE to '0' then try the esc calibration?
Great idea, but it did not seem to make a difference...thanks!
3dr radio worked for me with APM dev 3.4 but wifi / BT no go. Using APM P2 GCS
+1 Same set up, worked with no problems. Wifi looks to be a ways off on the APM stack.
cheers ,
off topic but i'm ready to pay my share for development when the button is enabled.
Philip: any news about stock?
I am in Chicago.
Nice, thank's.
85
86
87
88
89
of 110 Next
