This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens. Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
Here is a clip of it flying, or trying to. I can only assume the massive wobble is the ESC calibration.
Throttle stick seems erratic too.
There is an adjustment on that at least on the APM code. You can have them spin slowly or not at all... at least that's what I remember.
or if it's in throw mode they won't spin by default ... I'm sure it's irrelevant to the issue.... but just saying...
Thanks for the quick response
Thats what I thought too...I don't see any way I can do the ESC calibration since all at once is not working thru the APM firmware and PixRacer.
What brand ESCs are you using?
It seems to be slow to react too, when im throttle down fast, its still spinning up sometimes
My guess is you're using "latest"? So the code was loaded by pressing Ctrl-Q on the MP's firmware install screen? If that's the case then you're beta testing Copter-3.4 and it's modified motor spool up logic. That logic is that it has a 0.5 sec spool up (or down) time. Perhaps we need to allow that time to be higher or lower depending upon the frame (big copters probably want it slow, small copters want it really short).
Randy, I was using the normal download firmware, I did not know about Control-Q till now. Says "Trunck Firmware 3.4" should I be using that?
78
79
80
81
82
of 110 Next
