1.Introduction of Traffic flow and Height Detector
This plan use Benewake company’s product TFmini-Plus combined with Arduino-UNO.
The usage:count flowrate and height.
Equipment and wires
2.1    Equipment
  • Benewake TFmini-Plus
3691381435?profile=original
TFmini-Plus detail is on the TFmini-Plus Instructions on benewake website: http://en.benewake.com/download
  • Arduino-UNO
3691381491?profile=original
Detail introductions and study of Arduino is on the website below:
Chinese community:http://www.arduino.cn/
English Website:https://www.arduino.cc/
  • Computer
3691381536?profile=original
The computer is used as the function of program writing, uploading and data displaying. Data display function can be upgraded and optimized later, such as increasing the display screen to display current traffic and height data, and broadcasting greetings such as "Welcome" with speaker.
  • Wires
3691381607?profile=original
Dupont Line——Used for Plus and UNO board connection (Plus terminal removable)
USB Square Port Data Connection Line——Used to connect UNO board to computer
2.2           Wiring3691381590?profile=original
TFmini Plus product line is defined as:red+5V,black GND,green TX,white RX;TFmini-Plus The supply voltage is 5V,so connect directly,For other radars, please refer to the product specifications,to ensure normal power supply;
Serial communication connection needs attention,pin 2 ports of TX terminal plate for arduino UNO plate radar(RX of soft serial 1),pin 3 ports of radar RX terminal board(TX of soft serial 1)this is related to the programming in the following article.
  1. Measuring Principle of Human Flow Height
  • After the LiDAR start, set the installing height, height limit, lower limit.
  • When the people enter the detection area, the data will goes up, output number of people, every time this happens, number of people plus one, then output the number.
  • When the people enter the detection area, the data will wave around the height limit, compare it with Height, Height is the peak of the data wave
  • When people go out the detection area, the data goes down, output Height.
  1. program chart
3691381665?profile=original
5.Programming
The implementation of this routine requires at least two serial ports,a data receiving radar,another is used to output data to the computer for display. You can copy and paste the following code into the IDE program edit window,you can also open the corresponding attachment file directly.
(Get the file? Email us via: bw@benewake.com)
Number_Height
#include<SoftwareSerial.h>// Soft string oral document
SoftwareSerial Serial1(2,3); // Define the name of the soft serial port Serial1,and pin2 is defined as RX,pin3 is designated as TX /* For Arduino boards with multiple serial ports, such as DUE boards,comment out the above two pieces of code and use Serial 1 serial port directly. */ int dist;// Distance LiDAR detected
int strength;//LiDAR signal intensity,which is implausible if the data is under 100
int IH=230;//Height of  installing LiDAR(need to be set),need to adjust based on the black object in real
int H;//Height
int h=0;//last detected height
int check;//Check the stored data
int i;
int Number=0;//number of people
int Height=0;//Maxmium of height
int up=50;//height limit(Need to be set),height of the object is credible if is over the limit
int down=40;//lower limit(Need to be set),height lower than lower limit over the height limit will be counted, in case the height is equal to the height limit exactly which will case data waving and conduct errors.
int uart[9];//Store LiDAR detected data
const int HEADER=0x59;// pockets frame header
void setup()
Serial.begin(115200);// Set Baud Rate of Connecting Serial Port of Arduino and Computer
Serial1.begin(115200);//Set Baud Rate of Connecting Serial Port of Arduino and LiDAR
void loop()
if (Serial1.available())//Check SATA have data input or not
if(Serial1.read()==HEADER)// Decide pockets frame header 0x59
uart[0]=HEADER;
if(Serial1.read()==HEADER)//Decide pockets frame header 0x59
uart[1]=HEADER;
for(i=2;i<9;i++)//Store the data into array
uart[i]=Serial1.read();
check=uart[0]+uart[1]+uart[2]+uart[3]+uart[4]+uart[5]+uart[6]+uart[7];
if(uart[8]==(check&0xff))//Check the received number following the agreement {
dist=uart[2]+uart[3]*256;//calculate the distance
strength=uart[4]+uart[5]*256;//]calculate intensity of the signal
H=IH-dist;//calculate height
/*Detect number of people*/
/*theory: when data break through from lower limit to height limit, then number of people plus one */
if(H>=up&h<down)//when people enter the detecting area, the number of people plus one
Number=Number+1;
h=H;
Height=H;
Serial.print("Number = ");
Serial.print(Number);//Output the value
Serial.print('\t');
if(H>=up&h>=down)//When people are within the detecting area, compare the values to find the Maximum one.
if(Height<H)
Height=H;
if(H<down&h>=up)//When people walked out of the detecting area, the height outputted reach to peak, meanwhile it will be reset to zero.
Serial.print("Height = ");
Serial.print(Height);//Output the height
Serial.print('\n');
h=H;
Height=0;
//                       Serial.print("H = ");
//                       Serial.print(H);//Output the height
//                       Serial.print('\t');
//                       Serial.print("dist = ");
//                       Serial.print(dist);//Output LiDAR detected distance
//                       Serial.print("strength = ");
//                       Serial.print(strength);//Intensity of the output signal
//                       Serial.print('\n');
Upload the program to Arduino, open the serial monitor, then you can see the flowrate and height of the person. As the picture below:
3691381768?profile=original
  1. Notes
  • Installing height should based on the real black object to adjust, because different color have different reflectivity, so LiDAR will detect different signal. Installation height needs to be corrected according to actual black objects,Because different color objects have different reflectivity and different signals received by radar
  • When people are walking in a group, LiDAR can only detect one object, so this plan is suitable for detecting one person’s move. When many people walk together, the radar spot can only hit one object, and can only count plus one, which is suitable for single-person entry and exit scenarios.
  • If the facula didn’t hit on the head completely, then the height detected will be error. Considering the possible of mistake on height data while people walking, try to let the facula hit the feet, using the highest detected value to cut down error.
  • Buffer area is a "height limit - lower limit", which avoids the situation that the number of repetitions increases by 1 when the detection height happens to be a "height limit" object.
If you are interested, welcome to contact us: en.benewake.com
