Plane flew into tree - strange erratic flight
I wonder what happened here:
https://www.youtube.com/watch?v=tonnGOKT2RI&feature=plcp
The flight was right after a perfect one:
https://www.youtube.com/watch?v=DrnZ6CUfxFw&feature=context-chv
with no parameters changed, as far as I remember. This was in May 11 - it took over a month to find the airplane and some more time to recover it ;)
The plane had an APM2, with ArduPlane V2.33. The flight plan in the crash flight was flown before and was safe wrt terrain obstacles (here: Flight plan). The plane crashed 2/3 of the way from WP #3 to #4.
Has anyone seen this kind of erratic flight (altitude and speed) before? The crash occured because the plane flew much lower than in the plan and with too little throttle. Just a few secs before the crash it appears to make a last-ditch attempt to recover altitude but too late.
It was 28 m up in that tree, and was recoverd by shooting golf balls at it from at compressed air cannon :( The plane was shot to pieces, but amazingly, the APM2 and the GoPro are still alive. The APM2 delivers plausible values from all (IMU, mag, pressure, airspeed) sensors.
I will dig out the flight log as soon as I find out how.. (does not seem to work in Mission Planner).
Kind regards
Soren
  • Hi,
    OK so I was not the only one.. Good to know.
    Leimbach and Rote Fabrik were two different flights. Our airfield is situated between those places. It was of course no coincidence that I put the flight trajectory over the lake and over that green belt of trees in Leimbach (where the stream with the same name runs).
    With XBees (series ) I have had good connections over 5 km and flaky ones even longer. The biggest problrm is that Mission Planner keeps losing its "connection" when on the edge of range, even though enough data still arrives to follow the position of the plane. MP refused to interpret the data once dis"connected", and cant reconnect. That despite MavLink being stateless and needing no notion of connected or not. I hope that will be fixed...
    Kind regards, Søren
