Hi All,
First of all My escs and radio were calibrated.
At startup randomly one motor does not start after about 3-4 three minutes successfull run.
If motor starts there is no problem it continues to start and spin.
On my video look at startup, 2.07 and 3.00.
https://www.youtube.com/watch?v=GUF0xxDIX5U
My Quad config is:
Pixhaw with Arducopter 3.2.1
H4 Aliena 680 frame with Aerialmob landing gear
TM-MN4010 370Kv Motors
RCTimer 15x5.5 Propeller
TM-S35A ESCs
16A Gens Battery
3DR GPS Kit
15-10-23_18-58-58.part1.rar
15-10-23_18-58-58.part2.rar
  • The only time I had this happen to me turned out to be a faulty ESC... it started out with the motor randomly not starting up on arming... then progressed to not starting at all. It was a fairly quick progression, however, over the course of may a couple days before it failed all together. The only other thing I can think of is did you try calibrating your ESCs individually? I have read that calibrating all at once can sometimes not work, though I have never had this issue. Hope this helps in some way.
    • Hi,
      I think i solved the problem.
      I change THR_MIN value to 150 and RC_SPEED value to 100.
      I found this solution while searching in forums.
      Maybe THR_MIN change could be enough.
      I tested this at ground level.
      I will fly as soon as possible and We will see the results.
      Best regards.
