Q: What happens when the Pixhawk loses power during flight?
I recently suffered minor damage in a crash when I lost control over my hexa. I was about 10ft away from the hexa at takeoff and lost control when it was probably 25ft away. I know the receiver/transmitter is a possible culprit, but I did notice the power cable going to my Pixhawk was disconnected at the crash site. Did it come loose during the crash or before, I don't know. What I'd like to find out is what is the expected behavior when you are mid-flight and the Pixhawk goes dark.
Figuring out a root cause is going to be a process of elimination for me as well as measures to help beef the system up (redundant power sources, zip ties or whatever else I can find to keep connections secure, etc.
Thanks,
Erik
I am sure the current version has crash detection? If so and it did not log a crash then perhaps it lost power?
All depends on how much time between the crash and power loss - could it write?
Good point. I'll look for this tonight. I haven't - thus far - looked at the logs.
-Erik
So I've gone through the logs, but I can't say I have a better understanding of what actually happened. I ran the auto analysis on the log and this is the output I received from that:
Log File C:/Program Files (x86)/Mission Planner/logs/HEXAROTOR/1/2015-02-21 17-06-08.log
Size (kb) 1020.9130859375
No of lines 14075
Duration 0:04:35
Vehicletype ArduCopter
Firmware Version V3.2
Firmware Hash c8e0f3e1
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = UNKNOWN - No ATUN log data
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (11.22%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: IMU Mismatch = GOOD - (Mismatch: 0.39, WARN: 0.75, FAIL: 1.50)
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = GOOD -
I don't know if crash detection would show up in the auto analysis or not?
Sorry, I seem to have sent you on a bit of a while goose chase. :(
There is a crash detector but its triggered if the copter is upside down for more than 2 seconds and your throttle is zero.
http://copter.ardupilot.com/wiki/introduction/version-3-1-apmcopter...
and
https://www.youtube.com/watch?v=xaw3-oSahtE
So, it would not show up in yours if the power was disconnected during the crash.
Why not upload the logs so others can have a look?
Good suggestion. I will review the Pixhawk logs and see if I can determine if it lost power in the air or not. I'm pretty new to this, so wasn't even thinking that was an option initially.
I think I'd like to configure FAILSAFE like you have. Any tips on how to go about doing this?
Thanks,
Erik
Thanks for the links! I've already calibrated my power sensor, but I will enable the failsafe features for sure.
I don't really understand the log output, but the last line I have (line 14,074) was from my BARO. Does this mean the Pixhawk lost power abruptly mid-air? When I got to the crash site, the power cable going from my power sensor to the Pixhawk was disconnected. Just unsure if it came loose during flight, causing the crash... or if it came loose on impact. If I can figure this out somehow, I'll feel a lot better.
Thanks,
Erik
