SOLVED! PPM encoder V2 (328P) UPDATE FIRMWARE
PROBLEM:
PPM converter only worked if I first connected the Rx and only after a few second I connect the PPM converter.
SOLUTION:
Update firmware.
PROCEDURE:
1- Buy one AVR programer (arround 4USD) pay attention that you need one 6 pin connector cable.
2- Connect AVR programmer to PC and follow this tutorial:
http://elecrom.wordpress.com/2009/04/19/usbasp-tutorial-usbasp-driver-installation/
to install the windows/linux drivers (latest version of drivers found here http://www.fischl.de/usbasp/)
3- Download and install a programmer software: http://khazama.com/project/programmer/
4- Connect the AVR Programmer to PPM encoder board
5- Download the latest version of the firmware. I use this one because it worked fine http://www.rcgroups.com/forums/showpost.php?p=14347844&postcount=2445
6- Decompress the downloaded file to a folder.
7- Use the program installed in step 3 and select AVR: ATMEGA328P option.
8- Use the program installed in step 3 and select file Load EEPPROM and select the HEX file that suites you from step 6. In my case it was ppm_encoder_v4_3+bootloader_16Mhz.hex
9- Use the program installed in step 3 and select file Load EEPPROM and select the HEX file that suites you from step 6. In my case it was ppm_encoder_v4_3+bootloader_16Mhz.hex (don't know if this step is necessary)
10- Click the button Autoprogram.
This is my personal experience. If needed adapt it to your case.
  • Hello, if you purchased your PPM encoder from the DIY Drones store, it should come programmed with the latest firmware. If you would like to change the firmware, you will need a programmer, such as the AVRISP mkII programmer. It seems like it might be an issue with the RC gear.
