PPM output waveform
I am working on an engineering senior project to make a UAV.  My job is to get the plane flying, while two teammembers work on the payload.
The design criteria for the project required the use of a TI microcontroller somewhere in the project.  I am trying to replicate some of the functionality of the PPM encoder on an MSP430.  I already have it measuring all 8 channels out of my Flysky radio (probably quite inefficiently), and can send that data out of a serial port.  However, I have not successfully made a PPM signal that ardupilotmega can interpret.  I might have a poor conceptualization of the signal, or I might just be going about it the wrong way.  Could someone send me a picture of the whole PPM waveform?  Preferably an 8ch one, but any would do.
  • Neither the GUI or CLI report receiving any signals from the radio.
    What am I missing in the waveform?
    I haven't attached sensors yet, do they need to be present for it to analyze the PPM stream?
  • the attached picture is the closest approximation to the PPM waveform that I have made.  It has 8 pulses of 1.5ms each, separated by approximately 0.250us.  The pulse sets are delimited by a single 3.75ms pulse.
    Should that timing be read by the APM firmware?
    I have it going into pin PL0 on the atmega2560.  There is a solder jumper that could connect it also to PL1, should that be shorted?
    https://storage.ning.com/topology/rest/1.0/file/get/3692287417?profile=original
