Power problem – APM 2.x will not power up
07/14/16
Problem – APM 2.8 will not power up via power module but will power up normally with USB cable from PC in Mision Planner.
After I tried to add a buzzer to my APM (ordinary HobbyKing buzzer) via the ground and signal pins #6 on the long 16 pin rail (analog input pins) – now my APM will not power up except by USB and PC.
What did I brake?
Piezo Buzzer for KK2 KK2.1 & Naze32 Flight Control Boards (1pc)
I tried a spare power module from my Pixhawk – same problem.
I checked voltages on power module 6 leads – same in both power modules -
5.05, 5.05, 3.9, 4.5, 0, 0
Did I burn out internal fuse?
Help,
Vince
SOLVED – APM 2.x - no power
I opened my APM control board and checked voltages after diode and found low value 1.49v
So I jumpered the diode with a small yellow wire.
Now powers up fine.
So I guess I fried the diode by applying the buzzer on the Accessory rail.
I will be more careful now.
Many thanks to all the excellent documentation on the web for this control board.
I have attached the information I found on the web and a photo of my repiar.
Luck,
Vince
check diode.doc
Addendum:
I measured voltages on APM with power module power and ESC power on output rail -
Output rail 5.5v
Input rail 1.1v
Acessory rail 1.1v
Thanks,
Vince
