Distributor
Problem connecting Pixhawk and Futaba receiver
Hi
Two of my customers have trouble setting up the Pixhawk - I myself have a Pixhawk, but don't use a Futaba receiver, thereby I can't replicate the problem (I would like to find out if the problem is connected to the receiver they use, or something else).
Both use a Futaba R7008SB receiver.
Both managed to upload the Firmware to their Pixhawks - but they are not able to do the radio calibration (the Pixhawk doesn't "see" the receivers, the bars in the calibration are all grey).
They have nothing else connected to the Pixhawk, except receiver (connected to the right port / RC), buzzer, safety switch and USB cable.
The Pixhawk signals via the big LED "pre-arm check failed" (which makes sense ;)
They power the Pixhawk via USB and at the same time with a LiPo (via the Power Module).
The receiver is "found" by the remote, the LEDs are on, the setting of receiver and remote (regarding the use of the SBUS) seems to be right. They use the right port of the receiver to connect to the Pixhawk.
I am happy about any suggestions ...
Thanks a lot in advance
Felix
      • I ordered the receiver but now I see that my Pixhawk order says Backordered so who knows when I will be able to try out the combo.
  • This reply was deleted.
      Sorry, forgot to ask-which frsky receiver do you use? Thanks.
          That's great, thanks Yiannis
            Hi yiannis, just tried the ppm encoder this morning.......works like a dream. I can't say yet what was the issue as I flashed the stable firmware too. I may if I get enough time try the beta and see if it continues to work. Still all good, my new VTOL Uav design can now take it's first flight with the pixhawk. I may even get sales started this year now!
      Hi yiannis, thanks for your message. My ppm encoder should be here in a week so I will be trying the same thing- I will let you know the results. Good to know about the frsky receiver, it's very reassuring that you have a solution and that there is a back up plan-thanks for the information.
            Sorry to say but my nightmare continues.... My machine is completely unstable, it won't fly at all- even in stabilise mode. I have triple checked everything and followed all the troubleshooting guides. I am getting messages saying unable to decode message 152, 162 and 2 on apm planner. For some reason my mac will not let me connect to the cli, I just get scrolling characters. I am at a loss, everything is calibrated and connected properly. I do have issues with the throttle, on occasions only one motor will turn and other times they react inappropriately Any ideas? My next step is to try ppm encoder and stable version to see if that helps. I can't use qcontrol as everytime I try to flash firmware it says binary corrupted!
                Hi troy, yes sorry mate- I didn't mean to reply to you directly. All I will say though is I would avoid the pixhawk and futaba s-bus combination with your life. This has caused me nothing but trouble and despair. I don't know of anyone who has this working (if anyone has then please feel free to confirm). I know both xian and myself have got the throttle responding in calibration but mine is unflyable for some reason and Xian has indicated that he is having the same issues. If I find a solution I will let you know but if you want a pixhawk, I really recommend a different tx
                Best of luck mate
              • Tower Hobbies will be getting a big shipment in a couple of weeks. Just backorder one and yours will be one of the first to ship.
                http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCVRA&P=ML
    @Kobus: The servo is not supposed to move (this would be quite dangerous during calibration, imagine you have an electric motor connected). Its also unpowered - the power supply is for the avionics exclusively, you need to provide servo power from a different source. It would be unsafe (in general, there are setups where it would be fine) to solely rely on the servo power for the autopilot.
    You need to arm the autopilot probably first - in general, I recommend to spend some time with the documentation to familiarise yourself with the system.
        Thanks for all the info guys, I had it running for a while ( throttle needed reversing but all else was good). Strangely after 5 or so minutes it all went wrong. The roll now also does throttle and yaw, the throttle only does channel six and everything else is inop- I swear I did nothing! I'm sure this is a personal issue, kobus is right- it's a lot of new tech to get on top of quickly. Happy days!
