Distributor
Problem connecting Pixhawk and Futaba receiver
Hi
Two of my customers have trouble setting up the Pixhawk - I myself have a Pixhawk, but don't use a Futaba receiver, thereby I can't replicate the problem (I would like to find out if the problem is connected to the receiver they use, or something else).
Both use a Futaba R7008SB receiver.
Both managed to upload the Firmware to their Pixhawks - but they are not able to do the radio calibration (the Pixhawk doesn't "see" the receivers, the bars in the calibration are all grey).
They have nothing else connected to the Pixhawk, except receiver (connected to the right port / RC), buzzer, safety switch and USB cable.
The Pixhawk signals via the big LED "pre-arm check failed" (which makes sense ;)
They power the Pixhawk via USB and at the same time with a LiPo (via the Power Module).
The receiver is "found" by the remote, the LEDs are on, the setting of receiver and remote (regarding the use of the SBUS) seems to be right. They use the right port of the receiver to connect to the Pixhawk.
I am happy about any suggestions ...
Thanks a lot in advance
Felix
          Hmm, ran with qcontrol to check-same issues. Reflashed back with mission planner and it all works again. Think I will wait for stable version, just incase - the machine is too valuable......
  • This reply was deleted.
      In this video here:
      http://youtu.be/0Aawev2i6RY
      You have not actually connected the receiver correctly with its S.Bus output port. You need to plug into a different slot on the receiver. That's the one port which is rotated 90 degrees from the other ports. The R7008SB definitely works.
      -Lorenz
        • Hi Kobus,
          Please wait for APM 3.2 release. The R7008SB will not work with T14SG, AC3.1.x and Pixhawk.
          My R300SB and T10J is just work fine with APM3.2 Dev.
          Hi, for what it's worth I'm having exactly the same issues. I have the same setup as you and none of the slots/modes gets any result. It works fine in qcontrol so it looks like I will have to use that instead, bit of a shame as I would prefer mission planner. Best of luck. Thanks to all involved in setting this up, I know I must be doing something wrong :-(
    I have integrated SBUS2 support (for "R7008SB" Futaba rx, thanks Titan) inside "sbus.c" file on the master today, this could be replace the original by Titan (first test it at the ground).
    This include the latest sbus fix from Lorenz (the min/max limits here is in line with ppm-sum receivers, in the other one is too low/high).
    Here the file, try it if you want.
    sbus.c
    • Built the Pixhawk firmware - for the first time - using the above sbus.c. Long compile! Anyways, I was able to get my Futaba 14sg + R700SB working with the Pixhawk. I changed the receiver into mod B. Connecting into either the sbus or the sbus2 slot, on the receiver, works (connecting to RC IN on the Pixhawk).
      I'm nervous about having compiled this myself. I'd rather have an official firmware release. Hopefully we get an official release soon.
      One observation: When in radio calibration setup I get sluggish stick response when not calibrating. When calibrating stick response is smooth and fast. Is this normal?
      Anyways, nice to get the futaba finally working!
        Yes, this patch by Lorenz i think is in the next official release.
        Team is working also on the >8 channel support on sbus.
