Hi
Two of my customers have trouble setting up the Pixhawk - I myself have a Pixhawk, but don't use a Futaba receiver, thereby I can't replicate the problem (I would like to find out if the problem is connected to the receiver they use, or something else).
Both use a Futaba R7008SB receiver.
Both managed to upload the Firmware to their Pixhawks - but they are not able to do the radio calibration (the Pixhawk doesn't "see" the receivers, the bars in the calibration are all grey).
They have nothing else connected to the Pixhawk, except receiver (connected to the right port / RC), buzzer, safety switch and USB cable.
The Pixhawk signals via the big LED "pre-arm check failed" (which makes sense ;)
They power the Pixhawk via USB and at the same time with a LiPo (via the Power Module).
The receiver is "found" by the remote, the LEDs are on, the setting of receiver and remote (regarding the use of the SBUS) seems to be right. They use the right port of the receiver to connect to the Pixhawk.
I am happy about any suggestions ...
Thanks a lot in advance
Felix
What firmware version are you using? The reason I ask is that I only got mine working in the beta testing version but experienced too many control issues. I now use a ppm encoder and the stable firmware, everything works great. The receiver should be connected to the rc port not the sbus port (this is covered in the setup guide).
How are you powering your servo rail?, from the picture it looks unpowered. I stand to be corrected but I believe servos won't work otherwise ( I fly without servos)
Best of luck.
Glad to hear it mate, strange your default was set to 8 as 5 is the usual! Great news that you are now ready for the air, hope all goes well. A pleasure to be able to help, best of luck :-)
Have you connected the S.BUS out to the RC IN port of Pixhawk? This is (despite the suboptimal labelling) where it belongs. The port next to it is S.BUS out.
That's beta firmware so you can expect bugs. They will probably just copy over the airplane Sbus code for the final release. The airplane code works perfect with both R7003SB and R7008SB.
Good work by the development team. The Futaba Sbus problem is totally solved.
Apparently the airplane firmware has it all worked out. I did upgrade my airplane to V3.1.0 and have been flying every day. I am using channels 10 and 11 for landing flaps.
I just got my second airplane flying with a similar setup. I am now using a R7003SB and a R7008SB. I have tested 12 channels using pass through and they all work.
Good News
My 14SG and R7003SB telemetry receiver works with the Pixhawk. I am using V3.0.3 airplane firmware so I don’t know if the multirotor firmware will work.
The only thing I can’t figure out is how to calibrate channels 9-14. Any ideas?
Maybe that will be a future Mission Planner upgrade.
Are there any compatible issues with the small R7003SB receiver? I will be using it on an airplane with V3.0.3 firmware that says it’s 14 channel compatible.
I also need to have channels 9-11 output from the Pixhawk. Looks to me like I just set those channels to pass-through and they will come out on auxiliary outputs 1-3. Is that correct?
I need to know if this will work before I order a receiver.
1
2
3
4
5
of 9 Next
