Problem connecting USB
Hello, I'm having some problems trying to connect the APM trought the USB port. It had been working fine, but today I can't do it... It connects trought the 3DR Radio (PORT 6) but with the USB cable only the terminal tab connects and I can do all the tests and setup stuff but if I hit CONNECT on the Flight Data Tab on the mission planner, Mavlink do not connect, I've tried to reinstall the driver and change the port but nothing....
Please, as always I need your help... I appreciate... Thank you very much!
