Hi, since my 3DR radio was broken, i'm know trying to connect MP via blue tooth device(HC-06).
however, after 3 sec from pressing "connect" button, it always show that "connect fail" (LED on HC06 still blinking )
and today I saw someone solved this problem with updating the MP to the latest version(1.3.7), so I did it as well.
Then, it's weird that the window know showing "trying to connect, time out in _ sec" and the LED on my HC06 go solid, seems like they've found each other, but just can't connect.
Could any help me figure out what's wrong here?  Thanks.
(I'v changed the baud rate of device to 57200, and set the baud rate of MP to 115200)
  • Hi Gabriel, I do have the exact same problem. Did you solve it? How? I tried to get in the configuration of the hc-06 but without success!
    Thanks for your help
  • btw, the voltage of Pin TX RX at the telemetry port  is 4.0V,  is that normal?
  • can't do anything because of this bug....kinda going crazy right now......anyway, thank you for the info.  i'll try it:)
