  • Hi,
    I've testing two battery 3 cells  1x 4500 and 1x 2650  and return 4 volts, i've checking the cable and the resistors, no problem.
     is there a special setting for the correct display of the voltage ?
    By default, the 2.0.38 can not read the correct voltage, it must modify the code according to the batteries?
    thank you in advance for your help
    john
    Sounds like the configuration is set to read one cell instead of the full pack voltage.
Aug 25
