Posted by Carter Brock on November 28, 2009 at 5:40pm
Connected sensor on breadboard and with nothing connected to either port the 1 volt on the analog out pin floats around randomly about 200 millivolts either side of 1 volt. The 5 volt pin is rock solid. Is this normal for this sensor?
Well it may be defective if its been dropped, i saw somewhere that these things are very sensitive and you cant drop them even if they in a box, check the datasheet to verfy
