Problem with servos
Hi. I have a problem with apm2.5. I install this autopilot in my new plane and servos dont work. I check connect them to receiver and they work ok. Although with output apm they don't work. I followed all steps ...Does exist any parameter?
My best regards
  • JP1 was ON
    I dont use 3DR Power Module (at the moment!!!)
  • 100KM
    Are you using the latest firmware? 3.3.0? It has a arm / disarm feature now.
    • Yes I use latest firmware 3.3.0.
      I introduced ARMING_REQUIRE=0 and APM was armed.
      • 100KM
        Do the servos move at all when you power up (twitching or anything)? If not, check with a multimeter that you have voltage on the + / - pins coming out of the APM.
        • Output voltage is 1.44 volt
          • 100KM
            Ah so obviously you're not supplying enough voltage, power the output rail with 5v.
