Problem with some settings in MP 1.2.6
I am using MP 1.2.6 in Win7 and APM 1.4 (DIP-Switches disabled by reversed elevator and yaw setting) and I think some settings don't work as they should.
For example in 'Configuration'-->'Standard Params' --> Rudder Mix (KFF_RDDRMIX):  I can only set 0 or 1, but I can set i.e. 0.8 in 'Parameter List'. Similar with 'Configuration'-->'Advanced Params'-->'GPS to Baro Mix(Alt_Mix)' and 'Configuration'-->'Pitch Compensation(KFF_PTCHCOMP)'.
In 'Configuration'-->'Advanced Params'-->Airspeed use(ARSPD_USE)' the list shows 'Use', while at the same time 'Configuration'-->'Parameter List' shows '0' instead of '1'. Changing it delivers always reversed results.
Does anybody duplicate this or is this an individual problem ?
    i have fixed the Andvanced param tab to do the correct option. it will fix itself on the next update
