I'm Working on a BICOPTER ...
Being a newbie, i was confused about servo mixing, but thanks to V-TAIL mode in my FLYSKY FS-T6... its done!
But, when it comes to the ESCs connected in parallel to single throttle, everything went fine upto half throttle... and then, a motor stopped suddenly when i moved the throttle above 50%
I've double checked the connections, soldering, ... no problem with them,..
The motor and ESC worked perfect with another motor-esc pair not connected to the receiver...
What should i do now? Please help me out..
P.S. I'm trying it out without using a control board.. I just need it to hover and move a bit.. no serious utilities..
  • Try recalibarating the channel limits in the esc's. If they are working independantly fine, check that everythings soldered correctly, a loose wire in the power supply will make the esc stop as it cannot supply the amps. If you have a BEC in the receiver, make sure both red wires on the esc's are cut, or if you are using the bec in the esc, cut one esc's red wire. Earth and signal are needed, running both esc's off one signal is fine.
