Problems Quadcopter with ArduIMU V2
Hi, I'm doing a ArduIMU quadcopter with V2. I load Arduimu code without problems and HappyKillmore ArduimuTest is fine, but when I try the plate with a servo and transmitter receiver does nothing, no move to move the plate, and even when I move the levers on the transmitter. I tried to verions 1.5 1.6 1.7 1.81 and 1.8.2.
At first I did not use GPS or barometric or magnetometers.
Can anyone help?
Thank you for your attention and sorry for my english.
  • Hi Lenz, I load the Jose Julio´s code (ver 1.15), but i think my problem is because in JR the order channels is 1 throtle 2 aileron 3 elevator and 4 ruder, and I can not change the order they are read, and the times of each in the chain.
  • After loading the 1.7 code so good on the test, but when I test the board in the quad does nothing. My radio is JR with 2.4 module FRSKY DJT and receiver of FRSKY D8R v2 with PPM sum on channel 8 (updated).
    I think the problem may be because in JR the order of channels in the PPM train is 1-throttle, 2 aileron, 3 elevator, 4 rudder, while at Futaba the accelerator is ch 3. I can not find where you assign the order of the channels according to the receiver input signal.
